i have a 1967 20 hp johnson.when i throttle up it seems to slip like its a clutch slipping but i dont know if it has a clutch? i was told to check to see if it was a spun hub so i blocked the prop and tried to turn the flywheel and i couldnt so im open for more suggestions from anyone who may be able to help.if i run at a slow speed it acts fine its only when i throttle up it also seems to get hot when this happens.thanks to anyone who can help
