  #1
Old October 29th, 2004, 03:15 PM
mikeoliversr1 mikeoliversr1 is offline
Default Pontoon Cabin Project
I'd like to enclose the rearward portion of my 1987 24 foot pontoon. It has a canvas cover over an aluminum tubing frame for a roof to start with. I was thinking to enclose under the roof with a solid vinyl wall material. Large screened windows would be installed for making sure we could see where we were headed.To offset the added rearward weight I could move the two gas tanks and three batteries under the forward seats and ventilate the area to prevent going 'BOOM' while underway.My problem is I don't know of any wall material that would hold up to the Florida heat and salt environment. Also am I getting into a problem with moving gas tanks?Any help out there would be welcome!!Thanks, Mike, Pensacola, FL
  #2
Old October 29th, 2004, 04:00 PM
ccrawford ccrawford is offline
Default Re: Pontoon Cabin Project
Just finished a houseboat project where we used vinyl siding for outside and fiberglass pebbleboard (like in a bathroom) for the inside. Both of those materials will stand up to just about anything, and they are fairly easy to cut with the right blade on a jig saw.
  #3
Old October 29th, 2004, 04:22 PM
Solittle Solittle is offline
If the area under your present canvas roof is open now allowing the wind to flow freely that when you add sides you will be blocking the air flow. This will make steering very difficult in any kind of wind. Consider using canvas with zipers that you could roll up and get out of the way when the wind gets nasty.Marine canvas lasts quite well in the sun and salt. I would minimize the plastic windows as they go first due the UV rays of the sun. They will start to get cloudy in 2-3 years and become opaque and crack in 3-5 yrs. The next thing to go is the thread in the seams. That seems to last about 5 years then you have to get them re-sown. The canvas will last much longer if left open to the breezes.My canvas top (23' CC) is 10 years old and still holding up well. I have had the seams re-sown twice and the plastic window on my dodger replaced with canvas.
  #4
Old October 29th, 2004, 08:55 PM
Thanks for the thoughts about the material. It's going to be a winter project so I've got lots of time to work out the major and minor details.I can understand the 'hard to steer' thought but you advised to roll it up when it got nasty. I thought a cabin was for getting in out of the nasty weather.Mike
  #5
Old October 30th, 2004, 05:32 PM
A cabin - be it canvas or a solid material - will act just like a sail in any kind of wind. If the wind is strong enough you will not be able to maintain control. That is why you might want to consider canvas as it can be rolled up thus cutting wind resistance. If you never have any wind this is a non issue & use what you think best.
  #6
Old October 30th, 2004, 05:46 PM
624oldron 624oldron is offline
My friend Joe, whose sanity is often in question, built a houseboat on 2 pontoons, which he made, and fitted a small camper on top. It had stove and sink, good shelt etc.. But he got his weight distribution wrong and it sank.
  #7
Old October 31st, 2004, 04:22 AM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Mike,I've got a pontoon boat and thought of doing a cabin on it when the interior is ready to be replaced. I want something more secure than full canvas. Most of the pontoon boats with cabins have aluminum for the siding. It's the same material they use for the "spray skirts" on 99% of all pontoon boats. This method goes back to the early 1960s and is still the way they do it. Vinyl should work too but I think they use aluminum because it is a tad more rigid and requires less support structure...but that's just my opinion from looking at hurricane damaged mobile homes. Some cabins are insulated and others just a single skin on the outside. That's a consideration to deal with for weight and comfort.Windage is a problem but it just takes some time to learn the quirks. Trailering windage and height would be my concern. I see no problem relocating tanks and other gear forward to keep the boat balanced.Tracker makes a 24' "Party Hut" that sounds like what you want to do. There is also a company in Florida that makes cabin kits for pontoon boats but the price is waaay high. Google search and you will find them.Good luck.
  #8
Old November 2nd, 2004, 04:41 AM
Quote:
Originally posted by BillP: Mike,I've got a pontoon boat and thought of doing a cabin on it when the interior is ready to be replaced. I want something more secure than full canvas. Most of the pontoon boats with cabins have aluminum for the siding. It's the same material they use for the "spray skirts" on 99% of all pontoon boats. This method goes back to the early 1960s and is still the way they do it. Vinyl should work too but I think they use aluminum because it is a tad more rigid and requires less support structure...but that's just my opinion from looking at hurricane damaged mobile homes. Some cabins are insulated and others just a single skin on the outside. That's a consideration to deal with for weight and comfort.Windage is a problem but it just takes some time to learn the quirks. Trailering windage and height would be my concern. I see no problem relocating tanks and other gear forward to keep the boat balanced.Tracker makes a 24' "Party Hut" that sounds like what you want to do. There is also a company in Florida that makes cabin kits for pontoon boats but the price is waaay high. Google search and you will find them.Good luck.
  #9
Old November 2nd, 2004, 04:43 AM
Quote:
Originally posted by Mike Oliver:
Thanks for the positive suggestions. I've looked at the cabins in Florida and they are high dollar for what they are. Again, Thanks
  #10
Old November 2nd, 2004, 04:45 AM
Thanks for the info. It looks workable anyway.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pontoon Cabin Uncle Dave Boat Restoration and Building 17 April 14th, 2009 10:05 PM
LANDAU PONTOON/CABIN wbo Pontoons 8 September 24th, 2008 03:34 PM
pontoon cabin side wall material fthood Boat Restoration and Building 1 October 9th, 2006 10:28 AM
ProLine 20 cuddy cabin project JohnFla321k Boat Restoration and Building 2 May 21st, 2003 03:13 PM
Pontoon Boat Rebuild Project Deerdog Boat Topics and Questions (not engine topics) 2 February 21st, 2002 09:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
