  #1
Old April 29th, 2003, 05:44 AM
tony_cliffy tony_cliffy is offline
Default Repairing spark plug threads on '76 35HP Evinrude?
Hello! I may buy a small boat with a 1976 35HP Evinrude on it. I will have to buy it 'as is' without checking how it runs (no way around this). A visual check revealed a moderate amount of darkened residue adjacent to both spark plug holes. I was able to remove one plug by hand and noticed it became wobbly as I removed it and the threads in the head are noticably stripped. When I hand-tightened the spark plug it seemed snug but the outer residue (glazed engine oil? varnished gas?) suggests there may be blowby? Regardless, fixing the threads is something I think should be done.Is there a specific tool for cleaning up spark plug threads? They are not totally trashed as some I have seen and I am hoping running a thread cutter through there will improve the situation.Thanks!!!
  #2
Old April 29th, 2003, 06:03 AM
lakeman1999 lakeman1999 is offline
Default Re: Repairing spark plug threads on '76 35HP Evinrude?
In the past, I have filled the threads (not the complete hole) that remained in a plug hole with JB Weld (after cleaning, and wire brushing) used a tap to recut threads, turn motor over to blow debris out of cylinder, put in new plug, started up, and run fine from then on with no problems.
  #3
Old April 29th, 2003, 06:08 AM
Thanks for instructions. Sounds like a plan! I have never tapped a motor. Can I get just the tap for spark plugs or will I likely need to buy a whole kit?
  #4
Old April 29th, 2003, 06:22 AM
jim dozier jim dozier is offline
Remove the head and insert a heli-coil into the stripped plug hole. A helicoil is probably better than the original threads. Basically you drill out the hole with a specified diameter drill and retap with a specified larger diameter tap and then insert the helicoil threads (which are a stainless steel spring). If you don't want to do this yourself a machine shop will do it for a reasonable cost (call around). It will be good or better than new.
  #5
Old April 29th, 2003, 09:37 AM
Fixit Fixit is offline
reccomend removing the cyl. head and purchase a helicoil kit from about any automotive dealer and repair the plug holes -- operation is relitively simple process, replace head gaskets w/new and clean cyl. head etc before reassimbling.
  #6
Old April 29th, 2003, 09:48 AM
bhalsdorf bhalsdorf is offline
Go to your local Auto Parts store. They sell a kit to repair the threads. It includes a tap and helicoils. You are better off removing the head to do this as you can scratch up the cylinder walls badly with chips if you turn the motor over .
  #7
Old April 30th, 2003, 08:44 AM
Excellent, wel-articulated advice gentlemen!Thank you!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Spark plug gap on 1978 35HP Evinrude BobRitter Johnson & Evinrude Outboards 2 March 28th, 2007 04:16 PM
stripped spark plug threads OldRiverine Other Outboard Brands 1 September 5th, 2006 09:35 PM
Spark Plug threads half stripped.... Zep-- Johnson & Evinrude Outboards 7 August 14th, 2006 03:32 PM
Spark Plug Threads springbok Johnson & Evinrude Outboards 12 April 16th, 2004 07:38 PM
spark plug threads barry chang Johnson & Evinrude Outboards 6 January 17th, 2004 03:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
