Re: Pressure/Vaccume testing lower unit
Come on guys, you're guessing! LU should always be drained before pressure/vacuum testing. LU should hold some pressure/vacuum at the end of 45 minutes with some leakdown acceptable. Failure to drain will yield unpredictable results. In the case of pressure, it will mask prop shaft seal leaks.
