Re: Flywheel and recoil for 1956 Johnson 30hp
On the switch, you need to buy (or easily make) a switch that is exactly the opposite of any other modern auto or boat ignition switch. These may still be available as "older OMC" switches.<br /><br />Modern switches assume battery ignition and make contact to energize the circuit. You (and I) have magneto ignition, and the switch makes contact to kill the engine. Accordingly, we need a switch that has it's contacts open when we want to start and run. <br /><br />I simply bought a toggle switch to kill the engine from the dashboard, and alongside of that I have a (1958 Evinrude) key switch to turn the starter.<br /><br />Strongly suggest you buy the Clymer manual mentioned above at any boat store.
