I have a 1987 110 HP VRO THAT RUNS GOOD AT ALL RPMS BUT IT HAS A FUEL/OIL MIXTURE LEAKING OUT BELOW THE COWL. I GUESS IT IS A SEAL PROBLEM WITH THE CRANKCASE BUT WHERE DO I BEGIN TO LOOK.
There is a small drain hose that goes from the bottom port side of the air silencer base to the block. Look and see if its off or damaged.<br /><br />Good luck and stop yelling! Lol!
