  #1
Old April 14th, 2003, 12:55 PM
Brew Brew is offline
Default Setting Evinrude Timing - Joe Reeves?
I want to check/set the timing on my '86 Evinrude 140 and have read Joe Reeves' post on this in the past, but can't find it now using the search tool.Joe (or anyone else for that matter), can you please repost the procedure.Many thanks,Brew
  #2
Old April 14th, 2003, 06:47 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: Setting Evinrude Timing - Joe Reeves?
Brew..... (Timing At Cranking Speed 4°)The full spark advance can be adjusted without have the engine running at near full throttle as follows. To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary). Rig a spark tester and have the spark gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for. I don't know full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°. If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place. No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting. Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
  #3
Old April 15th, 2003, 07:28 AM
Thanks Joe!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Evinrude 140 Joe Reeves timing question. Theoutdoorsman Johnson & Evinrude Outboards 4 September 17th, 2006 02:27 PM
Joe Reeves Timing Tip CharlesW Johnson & Evinrude Outboards 12 July 18th, 2004 07:45 PM
TIMING ? FOR JOE REEVES mcpo Johnson & Evinrude Outboards 1 June 27th, 2004 12:24 PM
For Joe Reeves - Timing Questions Solittle Johnson & Evinrude Outboards 2 November 12th, 2002 03:58 PM
checking and setting timing on 1976 evinrude 70 hp engine Billyjack Johnson & Evinrude Outboards 1 July 25th, 2002 03:43 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
