  #1
Old April 13th, 2003, 01:37 PM
hcrumbie hcrumbie is offline
Default 1970 Evinrude "Selectric" 60hp Starter Trouble
My '70 Evinrude has been stored a few years. I went to start it, and after the checking most everything, put fuel to it and fired it up. It ran for about a second and I shut it down to check things out, but now the starter won't engage. I suspect it's something in the "selectric" shifter locking out the starter, but I haven't the slightest idea how to start diagnosing this problem.I appreciate ANY help 'yall may have to offer.RR
  #2
Old April 13th, 2003, 02:00 PM
almost retired again almost retired again is offline
Default Re: 1970 Evinrude "Selectric" 60hp Starter Trouble
Hey Riverrat;The most proble cause is the neutral safty switch on the port side of the engine, as the ground for the starter selonid goes through that switch. Seeing as how it started the first time, thats where I would start.Good luck
  #3
Old April 13th, 2003, 05:53 PM
Got it started...here's how.While searching this forum, I found a post that seemed to imply that the motor won't shift unless it's running....now how to get it running when it's in gear to allow it to shift???As the prop was already off, I setup the water supply, turned the ignition on and used the rope!! Off it went. Started working it through the gears and all 3 worked fine. I placed it in neutral and shut it down, then tried the starter. All worked fine! RR
  #4
Old April 14th, 2003, 11:08 AM
oldboat1 oldboat1 is offline
Ensign
I had a '70 85hp with the Selectric shift. I recall there was a lockout device (a plastic piece) that fit over the buttons on the inside of the box. The object was to prevent the user from physically pushing in the forward or reverse buttons unless the lever was in the neutral detent position -- which is also the only position which would close the electrical circuit to the starter. Does this figure in somehow?The plastic piece on mine broke, so I was able to start the motor in gear and push in the buttons regardless of the throttle lever position.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
"1970" 25hp evinrude wont start. charlesshaner Johnson & Evinrude Outboards 6 September 15th, 2005 01:00 AM
Evinrude 65 hp "Selectric Shift" no neutral stingray2232 Johnson & Evinrude Outboards 3 May 30th, 2005 06:56 PM
1970 40hp evinrude big twin "bogging down" aludeidmonkey Johnson & Evinrude Outboards 14 June 16th, 2003 09:43 AM
1999 8hp Evinrude starter motor "teeth" jammed against flywheel " sue_ring Johnson & Evinrude Outboards 3 September 21st, 2002 09:54 AM
1970 60 hp Evinrude "triumph" ken's boat Boat Topics and Questions (not engine topics) 1 July 3rd, 2002 02:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
