Re: Evinrude 1954 RD 16 25 hp
You can lock down the motor by using a piece of rope to put up the lock device, this will keep the motor from tilting up when you pull. Also you can tighten the adjuster nut so there is more friction when tilting. I have an RD14 and it's a bear to pull sometimes, especially when off of a boat. I had to bolt the test stand to the floor in order to test start it after refurbing it. You want to make sure your "carb sync" is set properly and that the butterfly is BARELY open when the lever is in low speed position. I had mine set so the butterfly was open too much, which let in too much air making it difficult to start AND made it very hard to pull and made it idle rough, if at all. I would buck and spit back and die. These motors are very sensitive to the sync adjustment and will not take much butterfly opening when the spark is retarded a lot.
