I have a 1988 Evinrude VRO V4, 110 HP, 2 stroke. I need to replace the stator and the rectifier/voltage regulator. To do so I need to pull the flywheel. I do not have an impact wrench an so will need to hold the flywheel stationary to remove the bolt. I do not wish to damage the flywheel and am wondering if anyone can suggest a good way to hold the flywheel stationary while I remove the bolt and also while I torque it back down. Any others tips about this job are welcome too.<br /><br />Any help you can be would be greatly appreciated.<br /><br />Steve Smith
