  #1
Old April 3rd, 2003, 06:50 PM
DougRaider DougRaider is offline
Default Evinrude 6 HP 1973 Shifting out of Gear
As I am underway, the motor shifts out of gear unless I hold the shifting lever forward. Is this caused by a faulty thrust bearing?
  #2
Old April 4th, 2003, 02:19 AM
papasage papasage is online now
Default Re: Evinrude 6 HP 1973 Shifting out of Gear
doug you may need to ajust your cable . or your shift rod loos or shift dog in foot worn . .ifit is the shift dog worn it could damage the gears which is expensive to replace. i have had a machine shop to dress the gears where the shiftdog inguage with good sucess. papasage>>>
  #3
Old August 30th, 2009, 11:02 PM
Kyle Anders Kyle Anders is offline
I have a '72 Evinrude 18 HP. It keeps "jumping" out of gear as I take off and keeps jumping out as I go across the lake. I can hold it in to a point and then it jumps out. It jumps seems to jump out and immediately back in gear. But it gradually gets worse, until you can't go much past an idle.
I just replaced the drive shaft. Everything else seems to be ok.
Any Ideas.
  #4
Old August 30th, 2009, 11:50 PM
crxess crxess is offline
It is rude to hijack someone elses thread.
I have to say in both cases the clutch dog is not enguaging properly. Do not continue use until the problem is corrected. it will only get worse.
If the clutch dog can be dressed to square the edges back, reinstall in the opposite direction. This will place the worn end working reverse. You rarely bully a motor in reverse and it should last.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60hp 1987 evinrude stalls at low rpm & when shifting in gear fab Johnson & Evinrude Outboards 7 May 23rd, 2008 01:12 PM
1973 115 Evinrude gear ratio? 85Sunbird Johnson & Evinrude Outboards 2 June 7th, 2004 01:42 PM
1973 6HP Evinrude Broken Pinion Gear cacioa Johnson & Evinrude Outboards 2 January 7th, 2004 05:03 AM
1973 Evinrude 70 shifting and steering problems stikman63 Johnson & Evinrude Outboards 0 July 7th, 2002 11:52 AM
Need gear ratio for 1973 Evinrude 65 HP 3 cyl ? Capt. Bob Johnson & Evinrude Outboards 3 June 30th, 2002 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
