Re: Johnson 15 (Want to make power)
Yes you can do all of this for educational or racing purposes......You need to do a search on the web for outfits that do outboard racing work. It WILL cost some money though, the crank will have to be magna fluxed as the connecting rods too. You may find that you will have to go thru several rods or even cranks to find one that's perfect and will stand up to operational 10,000-12,000 RPM. You will have to have port work done to the block and probably total replacement of carb, reeds and induction manifold. There are also exhaust plates that replace the standard removable one on the side of the engine, if it is equiped with one, to adapt external pair of tuned pipes(20% gain in power alone). There are also racing lower units made too for certain engines with specific gear ratios for racing. In addition you will probably have to run a cupped prop with the lower unit jacked so high that the prop will actually run out of the water at speed. On the extreme end 60 HP is attainable but reliability could only amount to a few hours of running time at these performace levels. A simple quick fixup, convert to alchohol fuel but your fuel consumption will almost double, and get next size up carb(much larger jets needed too). Fuel system must be converted to silicone based products to keep from dissolving.
