My motor is a 1985 120 johnson . I had taken it to a mechanic and had it checked for low rpms at wot. The boat was slow planing out. The guy said the motor was good(good spark, compression, and fuel).<br />I thought the prop was the problem since the motor had been checked. Today I took the plugs out and the top right plug had no gap at all.How could this happen?? Well I replaced the plug and hooked up to the water hose and cranked it. It sounded good. I took off the top right plug wire and there was no difference. All of the others would sound like the motor was bogging down when removed. Sounds like that cylinder isn't doing its job. What could be causing this and how much should it cost to repair? <br />Thanks for all help.
