I recently installed a tach and water pressure guage on my 80 85hp Evinrude. The problem I'm having is getting the lightning to work on the gauges. Should I run the ground to the tach for the pressure gauge and should I run a wire from the tach's light terminal to the panel light switch? I also installed a new toggle switch for my aerator and it won't work either.<br /><br />Dutch
