Hi again guys,<br /><br /> I have a 1959 Johnson seahorse 18HP.<br /> I lost alot of power 1 hour after buying it. Tried everything I know Carb's clean, Fuel filters clean, Points are new and adjusted correctly, Got good spark, have good compression, have good pressure in the gas tank, and have no leaks in the hoses, and have to ask for help.<br /> The bottom spark plug is always wet, idles good but will not get up to full speed. The bottom cylinar does not seem to be igniting the fuel because that cylinder is not running very hot. The top one on the other hand is. Could this be an indication of a leak and maybe some water is getting into the bottom cylinder causing it not to fire as it should.<br /> The motor did sit for 3 years before I bought it.<br /> Thanks for any input.
