Hi Guys,<br /><br />Please can anyone help with info on my Johnson 65hp 3-cylinder (model ref SJ65WMLP). What year? I've seen similar posts and replies explaining the OMC code 'INTRODUCES' but this doesn't seem to fit. (I'm in the UK, if this makes a difference.) Also, what sensors are there that would cause the alarm to squawk at me occasionally - usually before/just after starting? Motor runs well otherwise. Finally, will this engine charge the starting battery? What should charging voltage be?<br /><br />Thanks!<br /><br />Big Jock
