  #1
Old March 25th, 2003, 01:40 PM
dead in water dead in water is offline
Default setting carbs on 59 evinrude
Any hints on setting the low idle mix screws?Also,I took out the thermostat,the heads are just a little warm to the touch.Is this ok?50hp
  #2
Old March 25th, 2003, 03:32 PM
Default Re: setting carbs on 59 evinrude
Please Help?
  #3
Old March 25th, 2003, 03:40 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
The thermostat must be installed in that engine, otherwise it will run at the incorrect temperture which will result in piston/cylinder wall scoring etc.The correct procedure for adjusting the two barrel downdraft carburetor is as follows:(Carburetor Adjustments - Older V/4 Downdraft Carb) NOTE: The early model downdraft carburetors incorporated "Adjustable High Speed Jets". The later model downdraft carburetors used "Fixed High Speed Jets". Follow the below instructions accordingly. If you do not have adjustable high speed jets, ignore those paragraphs pertaining to same.Lift the center High Speed Control lever and turn it so that the point faces forward, resting on the high ridge. This will disengage the lever control gear from the individual high speed jets (slots). Have the slow speed needle valve knobs installed upside down so that they can be turned without encountering any obstruction.Gently seat each of the High Speed needle valves, then back each one out one (1) turn. Gently seat each of the Slow Speed needle valves, then back each one out one and one half (1-1/2) turns. NOTE... have the jam nut on the s/speed needles snug so that viberation won't have any effect on them, but loose enough so that you can turn them without a great amout of effort.(High Speed)With a reliable person at the wheel, and one kneeling in front of the engine, start the engine (yes, it will run lousy with the above initial needle valve settings), put it into forward gear, and apply full throttle. Start with the High Speed adjustment on the left using a screwdrive that properly fits the slot.(High Speed Adjustments)At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time.)(Slow Speed Adjustments)Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mjild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up).
  #4
Old March 25th, 2003, 03:50 PM
Thanks Joe,Iam trying to make this one last for one more year,before I get a new one.
  #5
Old March 26th, 2003, 03:08 AM
rwise rwise is offline
dead in water 1. the low speed sets at 1.5 turns out.2. the high speed sets at 3/8 turn out.3. the in the water adjust low speed for best idle.4. then WOT, in gear, with someone you trust with your boat and your life adjust the high speed jets for best proformance.5. repeat step 3 and 4 until you are happy with the responce.I have a 1958 50 hp this works, it may also need sync and link adjustments. If you do not have a book I can post the pages to do this on my web site for you to download. You would need winzip or something like it to uncompress the files. If you want/need it just post here or e-mail me, its in my profile.Richard
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
87 Mercury Classic 50 SETTING CARBS NGABaldEagle Mercury & Mariner Outboards 7 April 9th, 2007 09:12 AM
1972 1150 IL6....Setting up my carbs, looking for advice... stant1man Mercury & Mariner Outboards 3 May 6th, 2005 04:47 AM
Carburetor setting for 89' Evinrude 40 HP badasselectric Johnson & Evinrude Outboards 2 April 15th, 2003 06:16 AM
need help on setting carbs butch strals Johnson & Evinrude Outboards 2 September 10th, 2001 05:13 PM
Need help on setting up carbs on 81' 90 merc mbb Mercury & Mariner Outboards 1 April 21st, 2001 08:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
