Thanks Paul, I had run across some information about the kill switch set up for outboard motors after I posted this, so I went out and did a little testing.
I hooked up a generic key type ignition switch, which doesnt have nearly the amount of terminals as the original OEM switch, That is when I found I had no way to kill the motor,
I then tried grounding them together, and poof ! she shut right off
After finding that out, I was assumming that the extra terminals on the OEM switch provided a short between the two wires, or shorted them both to ground when key was in the OFF position.
But I was still a little nervous that I may toast something. Your post set my mind at ease
I am going to install an independant kill switch, since the new key switch has no provision to short these two wires.
Is it better to short them together, or to short them both to ground?? I can set it up either way.
Also, should I use a toggle switch so they remain shorted at all times when engine is off,(i.e. to bleed off excess voltage) or is a momentary kill switch (which will leave them open after shutdown) better??
I think read somewhere that 50:1 oil mixture is correct for this motor, Does that sound right?
It hasnt been run in a long time so I'm running her a little rich on oil right now.
Sorry to be such a bother, I am an auto mechanic, but dont know much about outboards.
Hopefully I can return the favor.
Thanks for all your help, it is greatly
appreciated.
