I wanted to make sure everything was set to factory specs on my '76 Johnson 35HP (I had the previous problem described on thread( http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=011753 )<br />,so I bought a new torque wrench and set about putting everything back together. I put the lower plug in fine, but the upper one lost it's resistance and the plug port now has no threads left- major bummer! <br /><br />I got a Helicoil kit and was going to install it. <br /><br />First I wanted to see if anyone could offer any advice or tips for when I do it. <br /><br />I was told by a friend to leave the head on and stuff a oily rag in to catch the debris, being careful to remove the oily rag with debris attached. I have good compression now, 120 PSI. They told me to leave the head on because I would not have to redo the head gasket and maybe mess it up -not me! I never break anything . <br /><br />Others have said to take off the head and get a new gasket- risking compression problems if I don't put the head back on correctly. <br />In reading some of the other posts on this board about stripped threads, I have seen references, but nothing that addresses all of my questions. <br /><br />One idea I saw was to fill the cyl with grease, then push it all out when done. What kind of grease should I use if I do this? I thought the grease would wreak havoc on the rings when the grease and oil don't mix and in turn burn the motor up. Someone else had said to use shaving cream to fill it then vacuum it out.<br />Any thoughts on either of those ideas, or does anybody have any other ideas?<br /><br />Anybody have pros or cons for either removing the head or leaving it on? Are head gaskets for this engine hard to come by? Can I make my own if I can't find one?<br /><br />Thanks for all your help! This is a great forum!
