trim position sender on alpha one
affa
Hello<br />I have an alpha one 1986 that i like to put an instrument on that shows the trim position.<br />Ive bought a Faria instrument that should fit, but im not sure which wire from the sender that sends the signal, <br />there are two wires from the sender and none of them works, the sender can be out of posisiton though, <br />but Ill check that, can you tell me where to put the wires?<br />The instrument has 4 connections: power, ground, signal and instrument lightning .<br />regards<br />Affa
Kenny Bush
Re: trim position sender on alpha one
AFFA, you may have to replace sending unit also. They are notorious for corroding.......
JB
Moving to I/O and Inboard
