no reverse
johnr2
I have a 1977 Johnson 115Hp which doesn't go into reverse any longer. All fluid levels are good and need some additional information. Please help<br />johnr@computingmadeeasy.net
Bob_VT
Re: no reverse
Check your linkage cable...see if it loosened or moved in it's bracket. Also check the linkage pivot point under the carbs....it too can slip.<br /><br />Bob
