  #1
Old March 15th, 2003, 04:20 PM
rons boat rons boat is offline
Default Any Pee Hole on THIS 115 Evinrude?
Most 115s I have seen have a Pee Hole. Several of my friends wanted me to post this and see if anyone knows the facts. Mod TE115TLEND G 03125497. OK somebody smarter than me explain why we can't find it.
  #2
Old March 15th, 2003, 04:35 PM
Hooty Hooty is offline
Default Re: Any Pee Hole on THIS 115 Evinrude?
It may not have one. I have an older 200hp and it didn't have one. I installed a water pressure gauge and now it has one. c/6Hooty
  #3
Old March 15th, 2003, 04:47 PM
I just looked at an exploded view of your lower engine cover and I can't tell if it has a pee hole or not. If it does, it will be on the bottom of the lower engine cover on the port side between 1/3 & 1/2 way back.g'luck & c/6Hooty
  #4
Old March 15th, 2003, 05:01 PM
ob ob is offline
Ron Davis,Your motor looks to be a 1992 model.I would think that it should be equipped to hook up a waterpump indicator.Look on the lower right corner of the exhaust cover and see if there is a small plug or capped-off elbow for a hose hook-up.Does the lower engine cover have a overboard nipple installed on the starboard side?
  #5
Old March 15th, 2003, 05:33 PM
We may have overlooked it. I will look again tomorrow as it is about 20 Miles from here. I bet my friends you guys would come up with the answer. Hooty and OB I will check out your info tommorrow or Monday. Tis a Mistery
  #6
Old March 16th, 2003, 05:53 PM
Anybody else know for sure on this model.
  #7
Old March 16th, 2003, 06:07 PM
I meant to post sooner. I looked at that exploded view again today and it shows a "nipple" on the starboard side of the bottom cover towards the rear. If it's the pee hole. it will protrude from the bottom about 1/8 - 3/16".If that ain't it, I don' know.c/6Hooty
  #8
Old March 16th, 2003, 06:11 PM
ob ob is offline
Hey Hooty,Put on your best spectacles and look on that drawing again and see if that 90 degree fitting leaving the bottom corner of the exhaust cover is where the water source feeds from.
  #9
Old March 16th, 2003, 06:16 PM
If i keep encouraging you guys, I know you will find the answer. I am sure you are getting close.
  #10
Old March 16th, 2003, 06:22 PM
Hooty, you said you put a pressure guage on yours and then it had a pee hole. Maybe if you relieve the pressure with a Pee Hole the pressure guage might not read right or did I misunderstand your earlier post?
  #11
Old March 16th, 2003, 06:27 PM
Tell ya'll what, here's the web site and it's a good one. Click on the engine make in the upper lefthand corner then the year, etc. When the drawing comes up, click on it and it'll enlarge. Again an excelent web site. http://www.boaterssupply.com/default.asp c/6Hooty
  #12
Old March 16th, 2003, 06:30 PM
No, you read right. The pressure gauge kit comes with the hook-up for the pee hole.c/6Hooty
  #13
Old March 16th, 2003, 06:35 PM
ob ob is offline
That's the site I was refering to Hooty.Can you see the 90 degree fitting that hooks to the lower starboard side of the exhaust cover?
  #14
Old March 16th, 2003, 06:38 PM
Which drawing?c/6Hooty
  #15
Old March 16th, 2003, 06:43 PM
ob ob is offline
Cylinder and crankcase drawing.Item #22
  #16
Old March 16th, 2003, 06:46 PM
Guys, my eyes ain't what they used to be but I guess you mean the crankcase drawing and that bubble cover in the back? I bet Hooty you are on to something with that Pee Hole thing. I still can't figure what they are trying to do with the pressure thing. Havn't seen one. How does it read, PSI or just idiot light?
  #17
Old March 16th, 2003, 06:50 PM
Roger, found the elbow and pressure reads on gauge in psi.c/6Hooty
  #18
Old March 16th, 2003, 06:53 PM
Yes, that's where the water source feeds from. I've got a 235 bubbleback that looks just like it.c/6Hooty
  #19
Old March 16th, 2003, 06:56 PM
ob ob is offline
Thanks Hooty.I wasn't sure.
  #20
Old March 16th, 2003, 06:59 PM
Thanks OB and Hooty. I printed this out to share with my friends and after a night rest maybe I can read that drawing as I am pooped. See ya later
  #21
Old March 16th, 2003, 07:00 PM
Por nada amago.c/6Hooty
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Drain hole,Seep hole,water leaking from powerhead JDB123 Mercury & Mariner Outboards 5 January 29th, 2007 11:17 PM
tell tale hole (weep hole) on 1986 Merc Mariner 75 eastshores Mercury & Mariner Outboards 1 May 14th, 2006 06:55 AM
9.5 Evinrude; What is this hole for? WEH Johnson & Evinrude Outboards 2 April 28th, 2003 06:34 PM
89 EVINRUDE 150 XP CAN'T GET OUT OF HOLE JWPAV Johnson & Evinrude Outboards 5 February 6th, 2003 10:34 AM
What is this hole for on my Evinrude?!? TrenchFisherman Johnson & Evinrude Outboards 39 August 9th, 2002 08:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
