  #1
Old March 13th, 2003, 05:43 PM
Randeye Randeye is offline
Default 1988 40HP Evinrude primer tube.
After several hours of searching and reading this forum, I found my problem!!Here's the deal... the rubber hose that runs from the primer solenoid to a "manifold" next to the fuel/vro pump, has been pinched behind the starter and has a hole in it. Obviously this can't be good and I'll fix it in the morning... will this cause the engine to have a hard time revving??? The engine runs fine until you give it much throttle, then it refuses to rev up. If the rubber hose that I described above has a hole in it,I don't see how that can keep it from revving because it should rev for a few seconds until the carb bowls are emptied... correct??Obviously I'm gonna find out for sure tomorrow, anyone have other thoughts?Thanks,Randy
  #2
Old March 14th, 2003, 01:31 AM
rudeafrican rudeafrican is offline
Default Re: 1988 40HP Evinrude primer tube.
Not very clear on what hose you are referring to as the primer hose should run to the VRO. The hose running from the "manifold" as you described, should be connected to the air motor on the VRO.Check out the explanation by Clanton on this link. It might be what you are referring to. hose worn
  #3
Old March 14th, 2003, 03:10 AM
First of all, thanks for the reply.... the "manifold" I'm referring to is at the VRO pump, it's a peice of plastic that has a larger tube coming from the VRO pump, a small tube going to the top carb, a small tube going to the primer solenoid, and a small tube going to the lower carb... in that order. The tube that has the hole in it, is the middle tube going to the primer solenoid.Sorry about calling the plastic, multi-tube fitting, a "manifold"... that's pipe-fitter slang for any common pipe that branches in mutiple directions.
  #4
Old March 14th, 2003, 03:13 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Randeye Any air leaks in the system will cause problems. It will cause the engine to run lean and contribute to the conditions you describe. Repair the hose and try it again. Might be a good time to inspect all the other hoses or replace them now before they fail. That is a common problem of the VRO's being blamed for failure.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #5
Old March 14th, 2003, 03:27 AM
Thank you rudeafrican and Rick.I'll replace the hose, check for other hose problems, grind the starter mounting plate for clearance, and give her another whirl.Randy
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
40hp primer solenoid setting? imported_bboat Johnson & Evinrude Outboards 5 November 6th, 2006 06:18 PM
Evinrude 1988 25hp Manual Primer Problem artherm Johnson & Evinrude Outboards 0 September 3rd, 2006 08:26 PM
exploded view of an 1988 Evinrude 40hp tie_one_on Johnson & Evinrude Outboards 2 June 15th, 2005 08:53 AM
1988 40hp tiller Evinrude motor makes metallic clanging noises and stalls vtach Johnson & Evinrude Outboards 1 September 20th, 2003 01:05 PM
Evinrude 40HP 1988 starter bad ? G DANE Johnson & Evinrude Outboards 11 May 27th, 2002 03:50 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
