Walterminator
- Jun 2, 2002
- 3
I have a 1972 Evinrude 60 HP 3 Cyinder with electric push button shift. I decided to hook up all<br />of the accesories ( bilge, lights, etc. ) to a dash mounted switch & fuse panel instead of a spider web<br />of wires to the battery. I ran a main + feed from the accesory ( "A" ) on the ignition switch and a<br />ground direct to the battery. When I turned the key to "on" all the switches lit up on the switch/fuse<br />panel and everything seemed fine. As soon as I turned on couple of accesories and it put a load<br />on the circuit everything went dead including the starting circuit. Now there is no power getting to <br />the ignition switch. I tested the switch with an ohmeter and it appears to be working ok ( circuits<br />open and close ). I used a jumper wire to confirm the starter is working. I am not getting any <br />power past the motor and no power to the ignition switch. I am certain I have blown some kind of <br />main fuse, fusible link, safety switch or something like that. I read an old repair manual which says<br />"do not hook up accesories to your key switch, hook them up direct to your battery". Sure, now I<br />know that. Anyway, does anyone know where or what to test or replace? One reference said<br />safety switch to ground, another said overloaded coil. I need to know what these parts look like<br />and where they are located on the engine. I am sure I can figure it out with a little help. I have<br />automotive mechanical knowlegde but I am new to the marine world. My brother is an electician<br />and he suggested if I wanted to keep the circuit the same; " key activated only", I can hook up a <br />relay to the key switch to operate a main power feed from the battery. I am more concerned about<br />getting the boat operational again. <br /><br />Thankyou <br />Walter
