I've got a 87 70 hp Johnson with the VRO removed by a local shop, just purchased this motor during the winter and was told that I needed to mix the oil (50:1) since VRO was removed.<br /><br />While on the lake last weekend the alarm buzzer went off, steady sound no breaks. I checked to see if the water pump was still "peeing" out the back and it was. The motor was not overly hot but I did not remove the cover. After a few minutes I turned the key (the buzzer was going off as soon as you turned the key to on) and the buzzer went away.<br /><br />We took off down the lake and the buzzer started again. I'm not sure if this motor has been sitting around for a few years but thought I would change the water pump. But after talking to local outboard mechanic he suggested it might be something else, few suggestions were the alarm box (I assume this is in the console box), thermostat, or heat sensor. <br /><br />I thought I'd ask here for some more advice. Is this a common problem??? Thanks for any help!! Anyway to check the control box, or thermostat???
