I have a 1999 150 Johnson V6 that starts and runs fine when cool. If I shut it down and try to restart after 30 minutes it idles down in 5 seconds and then stalls when put in gear. I don't push the key in as I do for a cold start. If I keep trying to restart it eventually floods. It does restart fine if I restart in 10 or 15 minutes. <br /><br />I tried running it in neutral at 1500 - 2000 rpm after a hot restart for 2 or 3 minutes and this seems to clear it out and I can get in gear and accellerate but it takes a minute or so to clear up. It runs fine when I get it going from in gear idle to 5500.<br /><br />The plugs are new Champions and were only slightly oily when I replaced them. When I took off the air box the carb intakes had some oil in them.<br />Also, There is a hose on the top of the airbox with a tee in it. From the tee one hose runs to the block and the other is not connected. Is this correct. The free hose has a plug in the end with a small 1/16" ? hole in it.<br /><br />Any ideas ?<br /><br />George
