I have a 1979 Evinrude 85HP for which a power tilt was later added. The motor and power tilt was installed on another boat and I'm attempting to install it on my Skeeter bass boat. The power tilt motor mounts inward between the motor mount brackets. I need a schematic in order to wire the motor.
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Re: Schematic - Evinrude V4 Power Tilt
I dont want to step on Schematics toes but he will need to know if you are using the two wire motor with relays or the three wire motor with a solenoid. Just a little more info!
