My Son tells me he hooked up the battery backward and "something smoked under the hood and made a loud hissing sound". After hooking up correctly the motor runs, but has an intermittent weak spark problem causing hard starts when spark is weak. <br /> What would smoke and make a whistling noise when the poles are reversed for about 30 seconds? The motor was not running or cranking when this hapened. I have put new parts on to fix problem, Powerpack, Stator, Rectifier, Coils, Ignition Switch but the problem won't go away.
