Re: Prop pitch for 98 150 carbed Evinrude
Also, Cavitation is not the product of the Prop. It is because either your Motor is set too high on the transom or you are starting out with the Motor Trimmed too far out. Try Tilting the bottom of the Motor in toward the Transom when you take off and the gradually raise it until optimum RPM's are attained, without cavitation at high speed. Ventalation may be a better Term, but for this purpose, I'll use Cavitation!
