Scenario: 1993 Evinrude 175, running at 2000-2500 rpms, overheat warning alarm sounded, but temperature gauge read normal. Water was streaming(appeared normally) from the pump indicator out of the motor. Alarm stopped, then changed to "no oil" alarm, and motor stopped in a cloud of smoke with a "pop."<br /><br />Several parts, wires, and plugs melted, indicating severe overheat. Oil injector was working, steady stream coming out, no obvious obstructions to the water intake. Any clue on causes? Thanks.
