  #1
Old February 7th, 2003, 06:50 AM
drackley drackley is offline
Default 115 Evinrude crank interchange?
I'm starting a rebuild on a 1994 evinrude 115 inboard (Seaswirl Squirt with a jet). I need a crankshaft and have an oportunity to pick up a 78 V4 115 crank new for a good price. My research shows that a rebuild kit may cover back to that vintage. Can anybody enlighten me on crank interchange for this 115JEER.Dirk
  #2
Old February 8th, 2003, 04:50 PM
clanton clanton is offline
Default Re: 115 Evinrude crank interchange?
The part numbers are not the same for 1978 and the numbers do not chain in the price book.
  #3
Old February 8th, 2003, 05:54 PM
Hooty Hooty is offline
Won't work. Different crank.c/6Hooty
  #4
Old February 9th, 2003, 06:03 AM
dpminc dpminc is offline
The 93 and up 90 degree v4 cranks have a removable wear sleeve at the PTO end. The seal part# is the same, and splining is the same, 78 should have the big center main. May work, but I havent tried. I do know the looper v4 cranks had a similar change in 93, and will interchange with each other. This is anecdotal though, as I havent tried this with the crossflow motors like yours.
  #5
Old February 10th, 2003, 02:51 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Yes you can get around the issue of the different bottoms on the cranks but the 78 has a small center main and you need one with the large center main. If you cant find one let me know, I may have the one you need.Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1988 110 HP Evinrude VRO interchange w2much Johnson & Evinrude Outboards 0 July 20th, 2006 09:48 PM
Evinrude 7.5 / 5.5 Interchange? GerryWm Non-Repair Outboard Discussions 1 August 23rd, 2005 02:04 PM
Evinrude V6 Rectifier interchange mship Johnson & Evinrude Outboards 6 February 23rd, 2004 05:37 AM
Lower unit interchange on evinrude 74 Yoan Johnson & Evinrude Outboards 1 August 22nd, 2003 06:38 AM
15 hp evinrude powerpack interchange knobby Johnson & Evinrude Outboards 7 March 9th, 2003 09:48 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
