  #1
Old July 31st, 2002, 05:02 PM
jetnick jetnick is offline
Default Inexperienced boater with a used boat - almost swamped it today. Advice please.
Hi. I confess. I'm an inexperienced boater. I bought a used 1975 Glassmaster tri-hull, 17 foot ski boat. 100 HP OMC I/O.To date, i've had the carb rebuilt (engine hums pretty nice), repainted the boat top and bottom, and most recently re-installed the wooden support under the motor mount (old one was rotten).Today, i had a bit of a scare and am scratching my head as to what happened exactly. After reading, if you can advise - please do... (ultimately, i'll take it to the shop but i'd like my fellow boater's to help educate me if possible).After dropping the boat in the water today - FOR THE FIRST TIME -, it started just fine and so off my two sons and i went.After about :10 minutes of things pretty normal, we stopped in idle and my 16 year old geared up for some tubing.As he did so, i noticed water accumulating in the stern.. in my opinion, a good bit of water. I determined that the drain plug was still in - and so decided to high-tail it back to the dock as the water was coming in appreciably faster with anything loose aft floor area floating around. (as a dramatic aside, as soon as i got my son back into the boat - the engine did quit as i powered up. It started right away, but for a moment, i had a flash of the boat swamping or sinking with the 3 of us in the middle of the lake ).The boat was way nose high and was reluctant to plane off and so i thus had my sons move forward. This helped.Got the boat back on the trailer, and by now i'd say the boat was about 1/8 or more full of water (water over ankle high in aft area of boat). Again, the drain plug was in and when i pulled it the water of course ran out.. Any ideas what might likely happened? Checking the rubber boot around the engine (100 horse OMC I/O), i can see no obvious holes.Wow, what a letdown after so much work getting the boat ready. If you took the time to read this and have any suggestions or comments - thank you in advance.Please feel free to post here or email me at jetnick@yahoo.comNick
  #2
Old July 31st, 2002, 05:43 PM
epresutti epresutti is offline
Default Re: Inexperienced boater with a used boat - almost swamped it today. Advice plea
Obviously there is a leak.Was the bildge pump running?Did the water come in faster when you were under power?Are there deck drains, and were those plugs in?You can put the drain plug in and start putting water into the boat. Then you will be able to see where the water is coming from. Obviously do this with a hose with the boat trailered. Be careful not to flood the engine compartment to the point where water can get into any vital components.I have also heard of people using food coloring in the water (the water you are adding) to get a better idea of the source of the leak.
  #3
Old July 31st, 2002, 05:57 PM
Capt. Bob Capt. Bob is offline
Another idea...check the raw water intake for leaks in the hose etc. and around the heat exchanger. The raw water pump may be pumping water into the boat.
  #4
Old July 31st, 2002, 07:46 PM
blifsey blifsey is offline
Had similar incident when on about our 3rd outing last summer. I have a fish and ski boat with live wells and a drain hose had come loose. End of hose was below the thru hull so whenever we all were jumping/swimming at back of boat, thru hull went below water level and we took on water. Do you have a bilge pump and did it work pumping out some of the water? Very important to have one that works. After fixing the hose (and to be sure there were no more leaks), I filled bilge with water hose. Then I took boat to lake on weekday (not busy). I left transom strapped down and backed boat into water. With the transom strapped down, boat couldn't float well and was pulled a little deeper into water. Then I opened bilge hatches and started looking for leaks with flashlight. Luckily, didn't find anymore so the hose was indeed my culprit. Also, you may need to determine if leaking is more when at rest with motor off, slow running or wide open running. Be sure to have some type of bucket or manual pump just in case also.Good luck,BL...
  #5
Old July 31st, 2002, 07:58 PM
sloopy sloopy is offline
its like when I installed aGuzzler pump backwards to a true hull 2 inches above the water,when at full throttle that hull is 2 iches below! the pump acts like a syphin and water comes pooring in!
  #6
Old July 31st, 2002, 08:02 PM
Ed, Bob, and Blifesy Wow, thank you all for your replies. I found this website quite by accident and was somewhat skeptical that anyone would respond.Thank you very much for your advice. I'm trying to get smart about this boating, and with shop manual in hand i will investigate all of your ideas...and then let the boat shop check it out just to be sure.again, thank you for your kind replies. Nick
  #7
Old July 31st, 2002, 09:06 PM
Bob_VT's Avatar
Bob_VT Bob_VT is online now
I agree with CPT Bob (yes all us Bob's stick together )Put a set of muffs on your motor, remove the cover and start your motor. It just may be a leak in the water intake. Normally it is just a gasket or worst case a brass cap that needs to be replaced due to cracking.Bob
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Sand in inboard engine of swamped boat RsDad Stupid Human Tricks While Boating/Fishing 2 June 24th, 2002 10:06 AM
New boater needs advice ArcherX Non-Repair Outboard Discussions 4 June 6th, 2002 11:30 AM
new boater needs advice! dave buckner Boat Topics and Questions (not engine topics) 3 May 28th, 2002 05:26 AM
1st time boater needs advice No EFI Boat Topics and Questions (not engine topics) 5 February 11th, 2002 10:58 AM
new boater needs advice cjensen83442 Non-Repair Outboard Discussions 1 October 11th, 2000 07:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
