I have a 1976 Johnson 40HP model # 40E76. I hit something, kicking up the motor. After getting back into open water, motor starts & runs fine, and moves forward & reverse at idle. As soon as I come up off of idle, motor races and motion ceases, as if the prop stops turning. (And no, it's not the shear pin.) Is there a clutch disc or something that is slipping above idle RPM?
