Re: 1995 88 johnson
Superman is right about checking the connections to and at the Battery. Also be sure you have a good battery, as it will be forever trying to charge a bad one! That happend to me on my 70 HP Evinrude. Was running 16 Volts, replaced battery, and was back down to the 13 Volt range. The old Battery would always start it, but it also was charging at a high rate! Good Luck.
