Doodling Dave
- Aug 31, 2002
- 2
Thanks OB.jhonson is on a stratos 201proxl. two 25gallon plastic fuel tanks.any idea how to remove fittings from top of tank?crossover valve appears fairly simple. i could only remove sending unit from tank to inspect inside of tank. did not check fittings because i could not figure out how to remove them.vent seems to be fine.with the seats and all out i was able to get to the tanks.putting pressure on the tank would cause fumes and a small amount of fuel to escape the vent.could the anti syphon valve be the problem if not the crossover valve.
