Re: spark plug wire
Hi leafs,<br />You can check the spark plug wire with an ohmmeter, you should getalmost zero ohms. It's a solid core wire, most automotive wires are a carbon type wire. To answer your question though, you could probly do it, but I would rather use an ohmmeter. It's only a piece of wire in there, and they very seldom break.<br />Good luck
