sharpsburg
- Aug 18, 2002
- 16
Hello again all...<br /> Seems I thought I was a better mechanic than I am. Maybe I should be like my ancestors and get a long boat with some paddles?! I cleaned up the fuel pump and carb. and now the engine will run wide open alright, but I must not have timed the engine correctly because it sounds like a diesel at slow speeds. I've already tried adjusting the low speed idle-doesn't alleviate the problem. Does it matter where I have the stator plate when I set the .0020 for each cylinder? I left the throttle linkage wide open (connected to the engine) when I checked and gauged the points. The engine also runs extremely erratic when I pull the throttle back from wide open to half throttle. It drops from plane in one heck of a hurry...the engine nearly kills. Help!!! I hate the thought of dropping $100 on something simple that I could have done myself!
