  #1
Old January 3rd, 2003, 12:42 PM
Chad Linder Chad Linder is offline
Default Late 60's model 18hp Evinrude shifting problems
I have an late 60's model 18hp Evinrude that is jumping out of forward and into nutral. The moter starts vibrating and then jumps out of gear. The shift handle vibrates before this happens. I broke down the lower untit and everything appered to be in good shape. This was the first lower untit that I have disasembled, but all the gears looked to be in good shape and I saw no metal in the lower untit oil. I noticed no change in the problem before and after going through the lower unit. Also I searched this site and did not find any post that describe this problem. Any help in this matter, or suggestions would be greatly appriciated.
  #2
Old January 3rd, 2003, 01:05 PM
steelespike steelespike is offline
Default Re: Late 60's model 18hp Evinrude shifting problems
Your symtoms are usually caused by a worn clutchdog.Take the cover off the lower unit and observe the movement when you shift.Be sure everythingis tight with no wobble.The shoulders on the dog need to have crisp edges.Be sure all parts are present and in good shape. Shoulders where thedog ingages the gears arent likely to be worn but should be checked.
  #3
Old January 3rd, 2003, 01:10 PM
A further note The clutch dog is on a spline on the propeller shaft and the dog actually drives the shaft when the dog engages the gears not the gears themselves. If you dont have a manual you should get one.
  #4
Old January 3rd, 2003, 01:31 PM
Everything in the lower until looked good. The gears looked to be slightly worn (it is a forty year old motor), but besides that in very good shape. No chips in any of the gears. Is it possible that the vibration is happining in the linkage rod. My thoughts are that the rod might be slipping at the connection. Could this be a possible cause of the problem, or am I off base?
  #5
Old January 3rd, 2003, 01:39 PM
DJ DJ is offline
Chad,It's the clutch dog. It may look good, but the edges need to be REAL SHARP, not just sort of.On some engines, you can turn them around and use the reverse side. Not sure about yours, you can try it.This happens because folks tend to EASE the engines into gear. Bad plan. They need to be shifted crisply and surely.
  #6
Old January 3rd, 2003, 04:11 PM
Thanks for the info. I'll break the lower unit apart and check it out. Is there anything I can do (file, grind, etc.) to make it work? Can I swap the forward and reverse dogs? The motor runs good, but I don't want to sink a lot of money into a forty year old motor.
  #7
Old January 3rd, 2003, 04:40 PM
rolmops's Avatar
rolmops rolmops is offline
Hello.They are not that expensive.Grinding takes material away,It does not add to it.But by all accounts,do check your linkage.The link that is in the very top of the exhaust-housing may well be responsible.Good luck.
__________________
Make sure the plug is in
  #8
Old January 3rd, 2003, 04:50 PM
The reason I was concerened about the linkage was, I had trouble getting the two rods to connect. I thought that it was possible that the two rods were not conecting at the nipples, and the vibration was causing just enough slippage to cause the motor to jump out of gear. Any idea where I would find clutch dogs for this make and model motor at a decent price? What kind of price should I be looking at.
  #9
Old January 3rd, 2003, 05:28 PM
wilde1j wilde1j is offline
There's only ONE clutch dog ... mark it before disassembly so you know which is forward end. You may need to flip it front to back AND swap the forward and reverse gears. Note that this will cause the motor to jump out of reverse rather than forward. I would be inclined to buy a new clutch dog, swap the forward and reverse gears (only if fully symetrical). As pointed out above, this condition is caused by poor shifting technique. I would guess a clutch dog would be ~ $50 to $75 for your motor. Try a message to Joe Reeves on this board. He worked for OMC for many years and still has a bunch of parts.The problem is NOT the linkage.
__________________
Jim
  #10
Old January 3rd, 2003, 05:37 PM
Thanks for everyone for all the help, I was under the impression that the price would be much more than that. I will contact him to see if he has the part.
  #11
Old January 3rd, 2003, 05:48 PM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Weight of late 60's Johnson 9.5 AaronG Johnson & Evinrude Outboards 2 August 30th, 2005 01:06 PM
Late 60's 33hp Ski-Twin AMcCall Johnson & Evinrude Outboards 7 July 12th, 2005 07:41 PM
late 60's 40 hp Bryan22 Mercury & Mariner Outboards 1 July 4th, 2005 04:43 PM
60's model evinrude 9.5hp fuel pump rcooke Johnson & Evinrude Outboards 1 April 21st, 2005 05:45 AM
Late 60's Evinrude feggebk Johnson & Evinrude Outboards 2 July 8th, 2003 05:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
