  #1
Old January 1st, 2003, 10:11 PM
gclemt gclemt is offline
Default 1973 Evinrude 140HP - Oily Discharge from Exhaust
I have recently purchased a '73 Evinrude 140, Model No: 135383M, Serial No: A87460. A workshop manual has been ordered. I've had trouble starting it, it wouldn't fire, despite cranking over. I eventually found no spark. From the advice given to others I hunted down the Black Yellow wire, and disconnected it from the power pack. It started and run, so I have a good idea of where to solve this problem. Now, I notice in the collective pool of water behind the motor there appears to have been an oily discharge with the exhaust gases. It appears to be a pale brown color. Is this normal? The motor hasn't been used for awhile.
  #2
Old January 1st, 2003, 10:33 PM
wishinIwasFishin wishinIwasFishin is offline
Default Re: 1973 Evinrude 140HP - Oily Discharge from Exhaust
g'day mate (fellow aussie)did the oil appear when you fist got it going after you had been cranking it as this may have built up exess oil in the exhaust and when you started it it would have expelled it (may be)or have you checked the gear case oil for water contamination or leakage cheers mateDaryl ps from gunnedah nsw
  #3
Old January 2nd, 2003, 12:29 AM
Hi Darryl,As I only ran it for a few minutes I'd say it occured straight away, and yes, it could have been a build-up. I'm yet to check the condition/level of the oil in the L/U.Regards, Graeme
  #4
Old January 2nd, 2003, 06:32 AM
OBJ's Avatar
OBJ OBJ is offline
Hey gclemt...Hows things downunder?Fishin is probably correct say'n it's from the exhaust. Not all the oil gets burner during ignition and whan the motor is upright has a tendancy to leak out through the exhaust. The heavier the oil mix the more puddle you can get. Stay with the 50:1 mix.Got to tell you guys I spent some time in Sidney back in 1970. Went there for R&R. You guys got a great country there.Jim.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #5
Old January 21st, 2003, 12:11 AM
Just as a follow-up to my query, the oily discharge turned out to be excess fuel. This was caused by the hoses to the fuel pump being incorrectly fitted. I was getting enough fuel to idle (in a fashion) but the motor wouldn't pull and just died when the throttle was opened. Once corrected, and with the carbys cleaned out, the old motor runs perfectly, not a beat missed, no more discharge!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Oily sludge from exhaust 9.9 Evinrude REVISITED with PHOTOS Moody Blue Johnson & Evinrude Outboards 29 January 5th, 2007 12:27 PM
1973-4 115 water discharge? Austinm Johnson & Evinrude Outboards 8 May 19th, 2006 07:47 PM
exhaust & water discharge Alws55 Johnson & Evinrude Outboards 3 April 28th, 2006 04:39 PM
2002 ox66 250 oily exhaust residue below exhaust holes tobias pardue Yamaha & Suzuki Outboards 5 July 16th, 2004 04:11 PM
Oily discharge from water intake Tony Ryburn Johnson & Evinrude Outboards 1 September 12th, 2003 09:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
