PeterDale.... That problem is usually caused by someone not installing a "O" Ring at the top ridge just under the top splines (if that ridge exists) or/and not applying grease to the splines. This allows water (slight spray at times) to enter the splined area and results in rusting the driveshaft to the crankshaft splines.
If this is the case, the only cure is to grab onto the driveshaft with vice grips at a non critical area and using a hammer etc, then carefully drive it out of the crankshaft. Good luck....
