Took the boat out again. Had a lot of problems getting it started. We had almost run out of gas the last time we were out. Finally had to prime it probably 20 times before it finally started. We have a 1978 Evinrude 175 VRO outboard. Primer bulb never did get hard. Ran great until we decided to stop and fish for a while. Fished for about an hour then started up. Started just fine but wouldn't go past 1500 rpm's. Finally put it in neutral and used the warm up lever to rev it up for a couple of minutes. Then it took off just fine and ran wide open. Any ideas on what might be causing this problem?
