Re: Pitch
A lower numerical pitch will get you out of the hole faster in most cases.<br /><br />Pitch refers to the theoretical forward motion that the prop would cause were there no slippage. Think of it like a screw being twisted into wood. If you make one full turn with the screwdriver how far in would the screw go? With props is how far forward would it go with one full turn of the prop - measured in inches.<br /><br />So a 20" pitch prop would move twenty inches forward in one revolution if there were no slip. The smaller the pitch the less distance you engine's energy is applied over, which is to say a greater surplus of energy will be available to cause accelleration. Then think of the same engine with a 16 inch pitch prop on it. The engine puts out the same energy but now that energy is only requried to push the boat 16" forward rather than 20". So there is more energy available per inch of forward motion with a smaller pitch prop and as a consequence the boat will accellerate faster.<br /><br />Thom
