  #1
Old November 20th, 2002, 09:50 AM
gboston gboston is offline
Default 1963 evinrude lightwin gearcase oil
i have a 1963 evinrude lightwin 3HP outboard the model is 3302S. i am trying to change the lower gearcase lube and the guy at the marina sold me some OMC HI-VIS Gearcase Lube. Is this the right stuff to use, or do i have an electric shift gearcase. thanks for the help.
  #2
Old November 20th, 2002, 10:21 AM
DJ DJ is offline
Default Re: 1963 evinrude lightwin gearcase oil
gboston,That's the right stuff. Don't forget to change the fill/drain plug seals!
  #3
Old November 20th, 2002, 11:35 AM
the only place i could find to fill it was a screw marked "oil level" when i popped it out the oil just started coming out. I didn't see a seal here, is this what you are talking about. I was just going to fill it back up in the same spot. I plan on getting a service manual for my motor as soon as i get the money (im a poor college student) thanks for the help
  #4
Old November 20th, 2002, 11:47 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Most Motors have a Fill/Drain screw at the bottom and a Vent screw at the top, on the bottom of the lower unit. You would remove the vent screw, then the drain screw. You fill it through the Drain Screw(Bottom) until it comes out of the Vent(Upper)Screw. Then install the vent Screw, with new seal on the screw and quickly remove the container at the fill hole and install that screw, also with a New seal(Washer or O-Ring).
__________________
Rick
"Boating is Life...All the rest is just Details"
  #5
Old November 20th, 2002, 12:02 PM
rickdb1boat,Yep your right, there was a "oil drain" screw below the one i was talking about before, it was kind of hard to see. Thanks for all the help guys.
  #6
Old November 20th, 2002, 12:26 PM
DJ DJ is offline
gboston,The seals are attaced to the screws. They may be stuck in the housing. They resemble O'Rings, yet arer made of nylon.They're CHEAP! You can get a handful for a couple of buck$.
  #7
Old November 20th, 2002, 03:24 PM
djohns19,I can get those at the local hardware store right? Or are they made of some kind of professional marine grade stuff? Thanks again
  #8
Old November 20th, 2002, 05:41 PM
DJ DJ is offline
gboston,No, they're not the same thing. Even at a boat/engine dealer-they're cheap.I wouldn't pay more than $0.50 a piece. Even at that price, they're taking advantage of you.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
3hp evinrude 1960's weedless gearcase of 90 deegree gearcase Tom987 Johnson & Evinrude Outboards 3 November 6th, 2004 10:43 AM
Need help with Evinrude Lightwin lightwin55 Johnson & Evinrude Outboards 2 July 3rd, 2004 11:47 PM
1963 Lightwin? petrolhead Johnson & Evinrude Outboards 2 July 3rd, 2004 12:08 AM
'73 Evinrude 4 Lightwin Ol' Den Johnson & Evinrude Outboards 1 June 5th, 2004 07:46 PM
old evinrude 4hp Lightwin fec Non-Repair Outboard Discussions 1 August 9th, 2003 09:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
