mark munro
- Aug 12, 2002
- 13
I have a 1990 225hp Evinrude #VE225TXESS that the Regulator/Rectifier appears to have gone toes up in. I noticed the last time out that the voltage was reading 12VDC on the dash so I did some diagnostics with general knowledge and according to the service manual.<br /><br /> I noted the terminal voltage was 12.? volts sitting, I fired up the engine and noted that the voltage dropped to 10.5 volts or so and then stayed at the previous voltage reading of 12.? I then ran it up a few thousand RPM and had no change. I disconnected the red lead from the regulator and checked for current to ground at idle and a few thousand RPM, no one home. I then checked the Stator resistance and had 0.2 ohms across the yellow leads and each yellow to ground was open. So I bought a regulator today and this is where my question begins:<br /><br />FYI, I noted in a similiar post this same problem and solution but I'm still not sure what to do.<br /><br /> The old regulator has a Red (output) lead, two yellow (stator) leads, a dark grey lead, and a blue lead. The new pack just has a Red, two yellow, and a light grey lead. I know what to do with the Red, and two yellow leads but should I hook the light grey wire on the new pack up to the terminal block where the dark grey wire on the old pack was connected then leave the wire on the terminal block where the blue wire on the old pack was connected not connected to anything?<br /><br />This was from the archive:<br /><br />Just an update about the purple wire from the reg/rect. Bombardier engineers decided against putting the purple wire on the reg/rect. they did alittle re-engineering of it. I was intrigued by it not having one, so i called them up and found out the scoop.. not needed anymore!!<br /><br />Purple .... blue, I always get that wrong <br /><br />What was the purpose of the purple wire and is the grey wire for the tach?<br /><br />Thanks in advance,<br />Mark
