Re: 2002 johnson 150's from 1992's
No, with VRO disconnected only three sensors remaining, 2 overheat 1 fuel restriction, old tach should work fine, self test on old horn should also work. After you get the engines running, I would remove powerpack cover and check for arcing between the ignition coil and steel plate that covers the pack, I see a lot of this. Id it is just i cylinder, the engine will drop 300 rpms each time it misfires.
