Re: Engine won't accelerate under load
I am by no means an expert here, but I do know my way around engines. I have just been battling the exact same issue with my Johnson 65, and have received several good ideas here on this board. Amoung them, pulling each plug one at a time to detect a dead or non-firing cyl. If there is no drop in RPM, that cyl. is not firing. Also, cleaning the carb of deposits from the oil. <br /><br />Something I found when troubleshooting, and I now think is the root of my engines problem, is a hairline crack in one of the ignition coils. The spark is intermitently jumping to ground on the coil mount, and there is a subsequent miss in the engine. So I think under load, it just cannot go. Mine bogs down at exactly 2000 RPM.<br /><br />One other issue that I had several years ago, and created similar but not exact symptoms, was a fuel line that was clogged, probably by deposits. The engine would idle, but no run under load. I got rid of the entire fuel line and replaced it.<br /><br />Good Luck!<br />TG
