  #1
Old November 13th, 2002, 12:54 PM
NOSLEEP NOSLEEP is offline
Default 95 evinrude 120 v4 looper timing
hello gentleman , i have replaced my 1985 evinrude 120 hp powerhead with 1995 120 hp powerhead the 85 models timing was set at 22 deg but i am not sure if this is the correct timing for the 95. i do have a omc manual but it only covers to 1990. thanks in advance
  #2
Old November 13th, 2002, 02:31 PM
clanton clanton is offline
Default Re: 95 evinrude 120 v4 looper timing
1995 parts book does not show a 120HP engine. 1994 OEM manual calls for 18 +- 1 degree. If powerhead came from OMC or the BOMB it would have a part number to ID the block.
  #3
Old November 13th, 2002, 03:03 PM
hello clanton i purchased this rebuild from a marine engine rebuilder in eastern canada he told me it was a 1995 120 p/head after installing it.i took it to a marine shop to have the timing set. they told me that the maximum advance they could get was 18 deg. so i replaced the fly wheel key because it was worn and was the probable cause of the maximum advance problem. i wish to reset it know, and have information on how to do so from one of the timing topics yesterday. i am now concerned that the p/head may not be 120 there is a h/power stamp on the old block. but the newblock has the h/power stamp machined off. is it posible that this 95 p/head could be wrong block ie:90 or 110 or even 130 if so would engine be same bore? and not mater
  #4
Old November 13th, 2002, 03:11 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
90's and 110's are crossflows. The very first (1985) V4 loopers were timed at 22 degrees. If you are using the carbs and ignition (including flywheel) from the 1985 you can use the timing for those components. Call your supplier and go by his advise as he is holding the key to your warranty.Good luck!
  #5
Old November 13th, 2002, 03:23 PM
At this point I agree with DH, go back to rebuilder, The first thing I would want to know is what year the powerhead realy is. With the parts and service manuals I have, I cant find a 1995 120. I also cant remember if this engine has quickstart, if it does engine must be up to temp, or bypass quickstart to check max timing,
  #6
Old November 13th, 2002, 03:24 PM
thank you for the info dhadley i am using all components from 85 p/head . all parts went on the new block no problem only thing that was different was some water plumbing that was attatched to the throttle. seemed to be some sort of diverter but was easely disconected and left off as new block had no way of attatching it.i will try to set timming at 22 deg
  #7
Old November 13th, 2002, 03:30 PM
dhadley engine has quick start.i thought i could set timing with sparkplugs out and at w o t 4deg back of recomended timing as per yesterdays timing topick i will checkwith marine rebuilder for timing setting. however marine shop didnt no for sure but thought it should be 19deg
  #8
Old November 13th, 2002, 03:36 PM
OK. You have a 93 or newer V4 looper without the throttle controled water valve and cross over hose. All the V4 loopers at that time were basically the same. I would still ask the warranty gods first. Unless you got it free and he has plenty more.Good luck!
  #9
Old November 13th, 2002, 03:37 PM
sorry clanton last post was directed at your reply, thanx
  #10
Old November 13th, 2002, 03:50 PM
If it has Quick Start you are not using the 1985 components. The timing should be at 18 degrees. Good luck!
  #11
Old November 13th, 2002, 04:00 PM
dhadley engine remote has quick start feature push in key for primer. is this not quick start .i have noticed before replacing power head that idle speed would not increase when cold and key pushed in. but it did seem to add more gas
  #12
Old November 13th, 2002, 04:23 PM
OK I see. The primer is operating as it should. Thats good.Let us know what your rebuilder says. Good luck!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude 120 looper 65whaler Johnson & Evinrude Outboards 12 January 9th, 2007 02:51 PM
94' Evinrude v4 Looper AJ__17@BELLSOUTH.NET Johnson & Evinrude Outboards 1 July 5th, 2006 06:01 AM
'88 120 looper, Idle timing jumping around-UPDATE! walleyehed Johnson & Evinrude Outboards 10 September 18th, 2005 08:17 PM
Evinrude 120 looper HC Johnson & Evinrude Outboards 4 April 23rd, 2005 06:20 PM
Bad # 5 in 87 evinrude 200 looper arhall Johnson & Evinrude Outboards 3 July 30th, 2003 05:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
