I've decided to replace the fuel and oil lines for my '86 Evinrude 140. My question is, is there a "marine grade" fuel/oil line I should be using or will any fuel line from a hose distributor suffice?<br /><br />Thanks.
There definately is a marine grade fuel line. Also, the type you select depends on whether above deck, or below.<br />Check with West Marine website. They should be able to explain.
