  #1
Old May 29th, 2002, 08:22 PM
kadkins kadkins is offline
Default 96 150 evinrude floods port side
engine starts fine then when power is applied falls flat on its face . All three plugs on port side are fouled.If I keep swapping plugs and open throttle as soon as engine starts it will finally pick up these cylinders and run until I try to idle for more than a minute.I have pulled carbs and checked needle seats and also checked elec choke sys. anyone have any thoughts ?? I just wanna go fishinthankskpa
  #2
Old May 30th, 2002, 06:25 AM
clanton clanton is offline
Default Re: 96 150 evinrude floods port side
Just a guess, but if there is a shift switch on the engine shift linkage, unplug the switch and try it.
  #3
Old May 30th, 2002, 09:47 AM
I guess I'm not sure of the logic with that. Is there a rev limit enabled with this switch? How would that account for flooding three cyls. on same side?Thanks for input Anymore Ideas??
  #4
Old May 30th, 2002, 10:18 AM
The shift switch kills cylinder 1,3,5 sometimes when shifting. 1,3,5 are on the stbr side, but it is possible to get the wires mixed on some engines.A better guess is power pack and timing sensor.
  #5
Old May 31st, 2002, 06:01 AM
Switch was defective, Thank you very much you saved me a great deal of headaches.Just a note to everyone this is a solid state switch , to bypass youmust plug the wires from the harness into one another.PROBLEM SOLVED!!! GONE FISHIN!!!!!!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Low Water flow from Port Side of gimbal Housing and Port Exhaust Elbow hot. roorancher Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 January 30th, 2007 10:11 AM
1991 120 hp port side getting hot !!! caldog101 Johnson & Evinrude Outboards 10 May 1st, 2006 06:54 PM
no spark from port side johnson_stx Johnson & Evinrude Outboards 1 October 13th, 2004 03:52 AM
wiseco piston port side or starboard side tvpear12 Johnson & Evinrude Outboards 11 August 27th, 2004 03:26 AM
88' EVINRUDE 110 NOT FIRING ON PORT SIDE Mmarycarroll Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 21st, 2004 09:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
