  #1
Old May 29th, 2002, 05:26 AM
bassscout bassscout is offline
Default '68 Evinrude 18 hp forward gear slipage
I recently acquired a 1968 Evinrude 18 hp Fastwin. The motor runs great, starts on the first or second pull.However, it slips out of forward gear. It seems to do this more when a load is put on, it runs fine when planed out.I found that if i put it into reverse, i can go to netural then to forward and it will work. However it slips out often.What is the problem?Is this worth fixing?How tough is it the fix?Thanks
  #2
Old May 29th, 2002, 07:46 AM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: '68 Evinrude 18 hp forward gear slipage
There are parts in the lower unit gear housing that are failing. Shift dogs?If you can get it off and apart, discern which parts are bad, order up new parts, put it back together you'll have it "made in the shade"
  #3
Old May 29th, 2002, 01:49 PM
rolmops's Avatar
rolmops rolmops is offline
Hello.The first thing you should do is get yourself a manual.These machines are quite simple and with a manual all you do is check each part that has to do with shifting.One by one the simplest and cheapest first until you hit the problem.It may be an adjustment or a loose screw.Good luck.
__________________
Make sure the plug is in
  #4
Old May 29th, 2002, 07:24 PM
12Footer's Avatar
12Footer 12Footer is offline
I think you have a sheared pin behind the prop. It may even look fine at first glance...Until you go to remove it,and find it is in three pieces.Couldn't hurt to check tho, as this is the part DESIGNED to fail,to protect the rest of the gear train.But if it doesn't come out in three pieces, you may have to pull the gearcase and check the shift dogs as Yepblaze sugested. Andd you'll need the book for that.
__________________
"Did you hear about the guy whose whole left side was cut off? He's all
right now."
  #5
Old May 31st, 2002, 08:48 AM
It's not the pin. Somone mentioned that it may be the rod that goes from the shift lever to the gears is out of adjustment. I'll try that next.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
35 hp 84 Evinrude jumps out of forward gear Johntree Johnson & Evinrude Outboards 3 April 6th, 2006 05:03 PM
35 hp 84 Evinrude jumps out of forward gear Johntree Non-Repair Outboard Discussions 1 April 6th, 2006 03:40 PM
87 175 V6 evinrude - not going into forward gear jacob_smith14 Johnson & Evinrude Outboards 1 June 16th, 2004 04:33 PM
74 Evinrude 70HP won't run in forward gear ruddy Johnson & Evinrude Outboards 2 September 25th, 2003 01:19 PM
68' evinrude 55 starter slipage voigto85 Johnson & Evinrude Outboards 1 June 4th, 2003 09:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
